NotImplementedError when loading dataset with Streamlit
Hi,
I have a Streamlit app that was working fine, which basically loads a dataset from HF (CSV-based dataset), but now, the app is crushed and shows the following error " NotImplementedError: Loading a dataset cached in a LocalFileSystem is not supported.". I have no idea what causing this error.
Any ideas on how to solve this error?
Thank you.
Updating datasets should fix the issue
pip install -U datasets
Same issue for me today. Tried pip install -U datasets but did not work
Thank you. The update solved the problem.
Thanks, it works.
It worked for me too, Thank you!
